ducky shine info
Hurry up with the Shine 4 as I have money waiting.
IMG_5706_zps2dfcf338.jpg~original
I'm using a Shine 3 TKL, love it. It's just had a couple of LEDs fail but to be honest I'm tempted not to send it in for repair to Ducky's UK support as I'd miss it too much! Says it all really :)
I use brown switches as I'm a gamer + do need to type fairly lengthy documents at times, the noise is nice and reassuring and the response from the keys is immense. Honestly I can't recommend it enough, even with my LED issue!
I am glad I have a TKL model though, makes gaming with it a better experience and it's fantastic if you're into flight sims etc as you can put your throttle on one side, joystick on the other and have them at a comfortable distance, essentially in-line with your shoulders.
You appear to be saving for two :D
They normally turn the RMA's round in 24hrs if you send it direct to the RMA centre if you can be without it for short time.
Switch's is all down to personal preference really I swear by Reds which I game/type on, but they can take a while to get used to when type if you like to spell correctly
Browns are by far the best selling switch for us in the UK I would describe them as an great all round switch that most people find easy to get used to when they first move from membrane boards.
Yeah I dropped them an e-mail last night so will send it directly :) Have a feeling my wife will claim it when it returns though so I may have to grab a second one soon!
It's astonishing how many people have tried it and then asked where I got it, despite previously thinking mechanical keyboards were just an expensive toy.
Do ducky have a range that dont have backlights? Would be nice to have a ducky for work but without the leds, plus im guessing it would be cheaper without the lights and complex control units
they come with both.
If I was at home i'd show you.
if you had red switch red LED id buy it now, but i can only see brown or black switch.Plus i want to know if i get custom keycaps what ones do i need as i want the LED to show the letter or symbol and not the whole key if you know what i mean.
We do the DK2087S Zero Shine TKL and DK2108SZ Zero Zone they are still backlit (it can be turned off same as the Shine series)
These are considerable cheaper than the Shine's but don't come will all the lighting models found on the Shine's
