Hi, just to check if you guys think I got some dud memory;
Bought some Corsair TwinX1024RE-3200LLPT memory- matched memory pair to upgrade from my old Corsair 512 MB single stick 2700 memory.
Pulled out the old memory, stuck in the matched pair in the first two slots, as adviced by the mobo (an Asrock 939A8X-M), restarted, and.... everything powers up, but there is no video signal out to the monitor, so can't even see bios. Removed, replaced old memory, and all is well. So tested each matched stick separately, both show cause same symptoms. Old memory still works absolutely fine.
Don't believe that there are any jumpers i need to change, to accept registered memory or anytihng......
thanks in advance
thanks in advance
