- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
As per the thread title the awesome R1600T are going on pre-order for £49.99inc VAT! These sell on epic levels and are in massive demand but due to how limited the stock can get we sometimes run out and stay out for what can be weeks!
These are coming in very soon, with in June so wait no longer than just a couple of weeks.
Get you pre-order in now as the price WILL be going back to £77.99inc once they land
Edifier R1600T Studio Plus 2.0 Monitors ** PRE ORDER PRICE ** @ £49.99 inc VAT
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
Was £77.99 Inc. VAT
Pre-Order Only £49.99 inc VAT.
ORDER NOW
- Distortion: 0.1%
- User manual
Was £77.99 Inc. VAT
ORDER NOW
