I'm trying to find a simple device with an ADSL port (rj11) and an Ethernet port that can bridge/convert PPPoE to PPPoA
For example, you purchase a decent firewall/router which has a WAN port that supports PPPoE but you live in an area where ADSL is the only option.
I realise I can use a cheap router to terminate the ADSL and then nat to the firewall or I can buy a public range of IP addresses and route to it but this is a problem I come across a lot and there must be a simple solution.
Draytek have a device that does exactly this, think it's the vigor 120 - we have one customer using this and performance is terrible and we have found several forum posts from other 120 users with the same issue.
Anyone aware of an alternative? Zoom 5715 was an option but looks discontinued
