25 Dec 2009 at 14:21 #1 topgazza topgazza Associate Joined 12 May 2004 Posts 266 I figure it doesn't matter which port my c drive is plugged into.....as the bios sorts out which boot order....am I correct ?
26 Dec 2009 at 01:38 #2 SsSsSsSsSnake SsSsSsSsSnake Associate Joined 19 Nov 2009 Posts 121 Location leicester whatever is set in the bios wont change because you change ports .
26 Dec 2009 at 16:08 #4 IAmATeaf IAmATeaf Soldato Joined 3 Apr 2007 Posts 7,320 Location South of the Watford Gap! The OS gives the drive the drive letter so once it's the C: drive it will always be C:
26 Dec 2009 at 17:01 #5 COYS COYS Associate Joined 30 Mar 2007 Posts 1,698 Location Leeds Yep and you can always change the other drive letters later using Disk Management
