- 4 Jun 2021
- Yorkshire
Looks pretty damn good! How often do you dust your PC? Do you end up with persistent dust which doesn't come off?
No particular schedule, just whenever I think on to do it (or typically when there's something else to do in the PC).
There might be a little bit of dust around after cleaning with the Compucleaner, but it usually looks pretty clean. Probably only get a better result with a brush or a cloth.
