DV Camcorder - Frames dropping on capture on D, E & F, but NOT C drive?
15 Nov 2003
Marlow
Although I've posted this on the video forum, I think this problem is more hard drive related hence me also posting it here:-
I'm very new to digital camcorders. I've connected a Sony Handycam up via firewire to my PC and when I started to try and capture footage I was alarmed to see about 2-5 frames being dropped per second.
I tried on all my large drives (D, E and F) and all behaved the same. I tried another application, and even plugged the firewire cable into a different header on the mother board. Frames continued to be lost!
HOWEVER!!! If I capture it to C then all's fine.
Now what I don't understand is my C & D drives are actually the same IDE drive (partitioned), and my E/F drives are the same (partitioned) SATA drive which should be as fast, if not faster than the IDE.
It's as if there's some sort of windows setting on D, E and F which is causing the dropping?
Any help would be appreciated as my C drive is not big enough to capture video footage, where as D,E and F have a hundred gig free!!
UPDATE - After a couple of defrags, D is now also drop free! So it's just my lovely (newer) SATA drive (E & F) that drops! Remind me never to buy SATA again!
what drive has your pagefile on it? most of the time windows can cache on any drive that has a page file on. thats most probebly why the C:\ drive is drop free.
D is drop free as well (now)... Infact as I sit here the 3rd hour of footage is being firewire'd in drop free to D.
C & D are an IDE drive. E & F are a newer SATA drive. Only E & F are (now) dropping... (See sig)
