Hi guys,
I recently moved my bedroom round a bit, and my Tv is now futher away from my PC than it was before. I connect my PC to my TV to watch films through as it elimantes the need for a DVD player.
I have a x1800xt graphics card which is dual DVI. My samsung Tv has VGA input, so I had one of those DVI to VGA blocks, but it is quite bulky and cant use it due to space behind my PC.
So it occured to me as opposed to try and find a 4-5 meter DVI to VGA cable, why not buy a 3 meter DVI cable, then convert it to VGA by the conector block and then run the VGA into my TV.
Is this a good idea? will I loose and signal quality or anything like that? as the entire cable run will be split 3 meters and then run for a further 1 and a half?
Or is a DVI to VGA cable thats 5 meters long a better option? and one last question is £16 a reasonable price for a 3 meter DVI lead?
Sorry for the lengthy post!
Thanks in advance
Benny C
Thanks in advance
Benny C
