DVI flicker problem
5 Jan 2010
Hi, I've got an odd problem that I'm finding it difficult to search for as it's hard to discribe for a search engine. Basically I've been using DVI to connect my monitor, DVI is on by default on the monitor and when I starting using the computer it's fine, after a while the screen flickers and shows the "dvi" logo to say it's connected to DVI (although it's already connected and working) then flickers on and continues to work normally again. This only ever seems to happen once until the monitor/computer is turned off and on again.
Cheers for any input!
