DVI or HDMI output?
18 Oct 2002
Newcastle, England
What's the best to use? I got the lovely Asus VE247H for Christmas and I'm running at 1920 x 1024 using dvi on my Radeon 7850. It's nice and sharp. But should I use the HDMI option at 1080p?
Hi
It wont make a difference in terms of picture quality the only reason to go HDMI is if you want sound to the monitor speakers as DVI does not carry audio :)
DVI is perfectly fine. You have no speakers so as above, you don't need HDMI to carry the audio :)
I hope you mean you're running 1920x1080 though :p The cable will make no difference to quality at all.
Sorry yes 1920x1080 dvi. The monitor has speakers but il never use as I have some edifiers. Il stick with dvi thanks
