I'm on Virgin Meida 10MB, NTL:120 modem, DLINK615 (wired connection)
Recently, i have been using torrents quite a lot (freeleech on a certain LEGAL webiste which ended 5 days ago), my bandwidth is very often throttled, however, since the freeleech, now it seems that my whenever i use torrents, my connection still says it's connected, but i cannot connect the internet (browser, itune store, msn) but the torrents still work. And the only way i can fix the connection is to disable the ethernet connection for around 15 minutes.
It also seems that recently i have bandwidth cuttouts (fairly normal occurance if i download too much) during 00.00 - 16.00 (non-throttling time).
So, do you think i need to get my modem replaced basically, or is this another problem?
