You can't rename an active partion to the best of my knowledge which is what you are seeking to do. My solution would be to disconnect your old hard drive and reformat the new one to ensure that it becomes the C:\ drive then reconnect the old drive and Windows should automatically rename it. Remember to make sure the bios is set to boot from the new drive.
