e system laptop problem
19 Feb 2007
i have a customer and her esystem 3086 has broken. the rj45 connector at rear on it has come loose and is not operational at all.
the laptop has internal wlan but it does not have a antenna.
just wanted to know , is the antenna internal on wlan enabled laptops? as her only hope is to buy a w router to be able to connect to the internet.
it doesn't even have a pcmcia slot.
thanks
thanks guys, very helpful , i shall be seeing her tomorrow and i will recommend she go with the w router.
thanks again
dog
