e2140 help
18 Mar 2006
hey
Recently built the following rig for the inlaws
asus vintage barebones
e2140
1gig geil ram
seagate 7200.10 80 gb hdd
samsung sata dvd rewriter
got it built and installed xp today, and on start up im getting the following error:
'Intel CPU uCode loading error
Press F1 to Resume'
after pressing F1 it boots up and runs perfectly, so any ideas what the problem is.
Cheers folks
dun
dun
5 Nov 2004
West Midlands
Cpu isn't supported I think. Update the bios if possible, if not I think you will have to press F1 when it boots, not a huge problem :)
18 Mar 2006
pretty sure the cpu is supported. The blurb for the asus says that it is at any rate.
Im not that fussed really, as, like i say, its running perfectly. Set my brother up with a amd x2 4600+ about 18months ago and it, at first experience, is as fast at that at basic operations. hugely impressed with the setup i got for the cash.
