- 9 May 2007
if you a reader of cpc then you might seen in the latest over clocking guide they said to over volt this cpu to 1.5v which is kinda high. and i was wondering should i over volt by that much? i thought after 1.45v it starts to degrade or die faster or something....
btw the temps seem to be fairly even between the 2 cores if i lap the cpu the temps will lower right? and whats the advantage of lower temps? longer life?
