- 5 Jul 2007
- London
I've wanted one of these forever so when one came up for sale locally advertised for not very much money I had to go and have a look. It's supposedly a one lady owner car with 71k miles on. The odo does ready 71k but also doesn't work so not sure how much to read into that, in any case the car didn't have any history. Overall for the money (£2250) it seems less rusty than I thought it would be, some rust on the arches and boot corners as well as front corner by the pedal, but doesn't seem to be anythng catastrophic just yet.
The front has dents on just about every panel at regular intervals so the supposed one lady owner can't have been too careful, or good at parking so that'll be my first area to try and address; followed shortly by the rear bodywork and boot floor. It drives pretty well though, stops, goes etc.
Photos from the ad:
When I got it back there were a few areas of immediate attention with the aim to get it through an MOT.
Indicators not working - Turned out to be the flasher relay by the indicator stalk, easy £20 fix
Tach/Odo not working - Took it apart but couldn't see anything obvious, read about batteries going on the SI board and could see mine were very low on voltage, so ordered some new batteries to attempt to install
Old alarm still wired in - Dealt with the rats nest of wires and pulled out the immobiliser/alarm and associated wiring, need to solder some connections back up but appear to have maintained all functions so far.
Which is when I found someones address book written into this:
Along with this newspaper clipping :lol:
Rear light cluster is missing an indicator lens - Ordered a second hand cluster to fit
That's when I came to the sunroof whcih has clearly been leaking and was visibly rusting on top:
So I decided to hoover up the rust and give it a light wire brushing just to remove some of the excess, and left the panel off for now. Not sure whether to repair the rusted panel or just to seal the thing up fully
Overall though it's relatively clean
And no visible rust on the scuttle:
Next steps are to make a decision on the sunroof; sort the rear lights and possible order some new front panels/bumpers to tidy all for the front end up. Longer term the idea when buying was to do an S54 swap and turn it into a full track/fast road toy. Will see how that plan develops as this seems like quite a nice car to really destroy doing that sort of thing. Otherwise just to tidy it up for the time being and get it through the MOT and go from there.
Thanks
Photos from the ad:
Thanks
