Anyone know where a mate should stick his simcard p) for his phone in his 530d. Me and a mate looked, and pretty much pulled the phone apart with no success...
Figure its in the base station? or somewhere else?
Ah, I know the one you mean, but I don't know the answer.. the only ones i've seen used are the motorolla one with the stretchy cable and the later bluetooth+snapin combo.
It probably takes a full size sim (credit card size) if it's anything like my old 540i. Under the hand-set, there should be a little piece of plastic that flips up when the hand-set is removed. This is the sim holder.
