E4300 or E6300
25 Apr 2004
Devon
As title.. these c2d CPU's seem similarly specced and similar in price, so I'm not sure which one to go for. The thing to consider is whichever one I choose will be in an SD32G2 Shuttle chassis with PC-5400 memory (the shuttle won't support above 667mhz)... not sure if this makes a difference!
Ta for any help
If you're not overclocking there will be minimal difference, but I would go with the E6300.
If you are overclocking however then I'd recommend the E4300 as it has a higher multiplier (Which will help you a lot, seeing as you can't really up your FSB much).
They are pretty much the same but the 9x miutipler on the e4300 means that you can use a lower FSB and maybe get a higer clock as a lot of mobos dont like going over 400 FSB.
Ordered the E4300, and other stuff:
Item: Intel Core 2 Duo E4300 1.86ghz Socket 775 FSB800 2MB Cache Retail Boxed Processor
Qty: 1Cost: 85.05
Item: 1GB DDR2 667MHz PC2-5400 240pin Extra Value Ram
Qty: 1Cost: 34.89
Item: Shuttle XPC SD32G2 Barebone - SKT775 for Core2 Duo
Qty: 1Cost: 168.59
Item: Sapphire X1300 XT 128MB GDDR3 VGA DVI TVO PCI-E
Qty: 1Cost: 45.09
Item: Sony AW-G170ASV 18xDVD±RW/RAM Dual Layer Writer Silver - Bare Drive
Qty: 1Cost: 17.12
423 including shipping.. should be a nice little system hopefully! Not for games obviously but should be good for movies , office etc.
