Not having much luck with this thing.
I have a coolant leak on the upper radiator hose on what looks to be a plastic screw(??). I'm not entirely certain what this is but coolant is coming out of it, not at an alarming rate but enough to steam a bit when I got to work this morning.
I seem to be struggling to find parts for my 330ci (01) on the net, does anyone have any tried and trusted sources for parts?
If I replace the entire upper hose it should sort it(I hope), I also hope that this is not simply the expansion tank letting off excess pressure.
The temp guage gets to half way and sits there, thermostat was replaced in January. Also noticed that the main radiator fan is coming on a lot over the past few days so have a replacement water temp sensor en route as well which i'll swap.
All input greatly appreciated.
