e5200 max cpu voltage
8 Mar 2009
hi guys im a noob over clocker and and was wondering what is the max volts i can put through my cpu without damaging my motherboard i only intend to keep the cpu it till christmas realy but will be keeping the motherboard for a while
at the mo its got 1.38125 volts in bios which is 1.360 in cpuz is this ok ?
and if so whats the max i can put through it
any help will be much appreciated
cheers
You're pretty high at the moment, but don't go over 1.4v, especially on air cooling. On water, people have had e5200's on 1.5v @ 4.0ghz.
Well 1.4v under load in CPU-Z. May be slightly more in the BIOS.
Under load, keep under 75-80deg.
will it damage my motherboard if i run the cpu volts at 1.4
Nope, it will just keep your CPU nice and toasty if it's not adequately cooled.
As already mentioned just make sure your load temps aren't getting too high at those voltages. If they are back off - and settle for a lesser clock if you've exhausted other BIOIS avenues for stability. Throwing volts at the vCore isn't always the solution...
Yeah that's fine. :)
Intel's max recommendation for 45nm CPU's is 1.36250v (24/7 under load), so providing you stay under this value, i don't see any problems. :)
