Hi all.
I wanted to build a gaming PC on the cheap and read up on modding a 771 processor and 775 board for compatibility and decided to give it a crack, first tried with an IPMEL-AE board which I already had with limited performance if I could make it to the desktop (would often hang on the 'starting windows' screen'. Now I've got a Foxconn G41MXE board which I've modded to fit the E5450 and had no luck. I've also fitted a Q6600 which also didn't POST despite being officially supported.
I've attempted to update the BIOS with no luck (both by USB and DVD), I'm just left with a flashing underscore on a black screen. Anything I'm missing?
Any ideas?
The Q6600 should work, but doesn't. I'm assuming it's struggling with the Quad cores as it works fine with my OC'd Pentium E2160 on 333mhz bus and 3GHz core speed.
Any ideas?
