E6300 v's old Athlon 64 3500 worth it ?
18 Oct 2002
up north
got the chance maybe of a change of mobo and cpu
at the moment have very limited funds but can swap out my old
ecs nforce 4 s939 mobo & A64 single core 3500
have the option to get
e6300 base model and very basic mobo with funds left, i am not into overclocking and have pc2700 to use as RAM
is it worth doing, if so what are the advantages
other than that i could go x2 4200 or something similar and keep the mobo
thanks
jase
Yeah, most Core 2 Duo motherboards require DDR2 RAM, so you'll probably need to ditch your old DDR because it physically won't fit int DDR2 slots.
However, the Asrock 775-Twins-HDTV Rev 2.0 motherboard accepts DDR and DDR2 RAM, and will work with Core 2 Duo processors thanks to it's Ati Xpress 200 chipset. So you could use your PC2700 (although I'm sure it would prove to be a bit of a performance bottleneck) until you can get some DDR2.
If you decide to go s939 X2, move quickly because chips are becoming scarce.
I would go for an X2 because its going to be cheaper and they still perform increadibly well, you can probably overclock it a bit too. I would have gone for an X2 3800 if this last batch of 4000+ didn't overclock so well
Couldn't have said it better myself.
