e6400 @ 3.2Ghz (mem max 450) higher?
17 Oct 2002
I've finally got my new system up and running, been playing clocking it today.
I got the RAM to 450 @ 2v @ 4-4-4-12 :)
I've just clocked the CPU to 3.2Ghz (400) @ 1.375 VCore (1.35 in cpuz)
I'm not sure if I should push it further. My temps atm using TAT to max out the CPU are: 38 idle 55 max (in speedfan)
I'm just going to install linux :) should give it a good test, not sure whether to push the mobo too much tho, I know I can get at least 450 out of the RAM tho. Pos 500 with higher voltage?
System: Asus P5W DH - GSkill 6400HZ 2Gb - e6400 - X1900XT
fulcrumer said:
What are your temps in TAT - rather than speedfan- you might not like them!!!
I use 1.425 on my 6700 to get 3.4.
On TAT it is - 54idle 65load
I think I'll leave it at 3.2Ghz for installing linux etc, might try for higher later :) was quite impressed with the RAM tho. Might push for more as I know the RAM can take it, I'm just a bit worried about the NB temps @ 450+fsb
Not sure if anyone is running 24/7 with 450fsb :confused:
i have an e6400 at 3.2 aswell but for me to go any higher than 400fsb i need to drop the multiplier because of the stupid p5w dh. love to see how you get on.
