Hey, I'm using an E6400, with stock fan at the moment, i plan to get
http://www.overclockers.co.uk/showproduct.php?prodid=HS-010-AS&groupid=701&catid=57&subcat=821
I'm also using AiBooster to overclock my CPU, and i turned it up to +15%, so i'm running at 2452Mhz atm, But when i try to turn it up to 20%, it instantly freezes... doesn't even get a chance to heat up...
The temperature is 50-62C on load, depending on the game (Crysis is the only thing i've seen take it past 60C)
So my questions are:
1. Why can't i overclock it any more?
2. Whats a safe heat for this processor to be running at?
3. am i likely to see a big difference in temperature switching from stock to my desired cooler?
