After swapping case fans & jigging some wires around I installed the temp monitoring utility yesterday & it reported the cpu @ 112 degrees! I rebooted & checked the bios and that also had the same temps.
I shut the pc down & a wire had dropped into the stock intel cooler & stopped the fan from spinning, once this was free & the pc restarted it ramped up to full speed.
I could then no longer enter the bios, it just hung & then took 5 attempts to load windows, it was just rebooting half way through. The fan gradually slowed down whilst doing this until it reached its normal inaudible speed. After that the pc appears to be fine again.
Now, is 112 degrees even possible & is it likely I have caused damage ?
) and it didnt throttle (at least not what I saw in CPUz anyways, although to be fair was in a rush to hit the power switch on the fan PSU)..
