E6600 + ABIT 32x Max stability issues
22 May 2003
Well folks, I am having some stability issues with this rig.
Specs are...
E6600
Cell Shock PC26400 4-4-4-12 2T
Abit 32x Max wifi with bios 1.2 beta 06
2x7200.10 segate 320gig in nVraid 0
BFG 800w psu
BFG 8800gtx oc2
I have run orthos on it for over 24hrs at 400fsb with a x6 mulitipler, giving 2.4gig cpu speed, so I figured the mobo was stable at this speed. I also tested the ram for 12+ hrs with memtest 1.70+.
To get that I had to use the following settings...
1066strap
1.35 vcore
2.10 vdimm
1.4 cpuvtt
1.4v NB
1.6v SB
1.35v HT
linked mode + memory at 2:1 (synced)
400 (1600) fsb (which gave 800mhz ram speed)
x4 ldt
I have run the cpu at 3.2gig (x8 muliplier) on stock volts (1.35vcore) for 24+hrs with orthos.
So now, I slap the multiplier on the cpu back to 9 to give 3.6gig, and run orthos. This is where the problems begin.
Running orthos at this speed has never given me a STOP. The machine just freezes solid. Sometimes it can be after a few mins, sometimes after a few hours.
I have tried vcores from 1.35 up to 1.55, with no change in the outcome. I have also tried a 1333 strap.
Cpu temps (coretemp) reach ~50'c with 1.55. I have an extra fan on the passive NB hs. I also have 2x120mm over 1/3 of mobo because I am using that geminII cpu hs.
Anyone have any idea what might be up with this? btw, something around the pwm area on the mobo screams when vcore is getting close to 1.55.
I do realise I could be beyond the limit of this cpu, but to run without issue at 3.2gig at stock volts means to me that there is still some way to go. With my old x2 box, if I got the red stop in orthos it would mean one thing, more cpu juice (as long as you are sure there are no mem errors etc).
Cheers for any advice,
Richie.
