Permabanned
HI Folks,
Just a quick question about temps , I replaced my 8800GTX cooler with a
HR-03-PLUS , I had to mount it cooler to the top ( i use pci slots) this has had
the knock on effect of blowing hot air towards my tuniq tower cpu cooler
which in turn has raised my cpu temps.
At idle my cpu is at about 43 deg C , under 100% orthos load its 66 is this too
hot ?
Iam debating trying a different fan inside my tuniq to see of this can help
failing that I might try the HR-03-PLUS passively.
Has anyone any thoughts on this ?
Any suggestions greatfully accepted
On the bright side my GPU went from 74 on idle to 57 on idle
hot ?
