Just built a new PC (see sig) and my E6600 seems WAY TOO HOT compared to other peoples.
It Idles at about 52 and goes up to 68 under load in TAT.
the nvidia monitor claims 47idle, 52 load
coretemp claims the same as TAT.
I have re-seated the (stock) HS about 5 times, with fresh AS5 each time, and it just won't go any cooler
anyone got any sugestions ? Can the stock HS really be this bad?
i know from the past that not having enough juice in the PSU can cause CPUs to run hot, is this the case with C2D processors ? I am using a Tagan 480W (U01).
on the bright side i am not getting any errors.
also, what should be the stock voltage? the mobo autos it at 1.35
