E6750 question
1 Jan 2005
Stoke on Trent
what speed of memory should you use with the E6750?
thanks for any help
and would the GA-G33M-DS2R be ok with that cpu?
It needs a minimum of PC2-5300. You'll need faster if overclocking.
And yes the GA-G33M-DS2R will run it fine.
thanks Cob so if i buy DDR2 - PC2-6400 it should run fine with it?
or would you get then next speed up?
im not gonna be overclocking it
also would the E6600 be better than the E6700?
thanks for the help
PC6400 will be fine for it.
And there's no reason to go for the E6600. The E6750 is faster and cheaper.
