HI All,
I have been running my CPU (E8400) at 3.6 GHz without any problems for quite some time now. I tried to reach 4GHz and I need some help with "fine tuning".
Everything goes good. 8 hours without any problems on Prime95, 3D Mark vantage runs ok and playing games without any issues. The problem comes when I try to convert movies to .mp4 (using Tipard Iphone Converter). After about 5 min from starting I get blue screen with error: Stop 0x124. When I put CPU back to 3.6 I can convert movies without any problems.
To reach 4GHz I only changed FSB to 445MHz and CPU voltage to 1.34V. Memory frequency sets itsef automatically when you changing FSB value on my motherboard. All other settings are on auto. Multiplier (set on auto) changes value between 6-9, so CPU doesn't have to run on 4GHz when not needed.
My config and settings:
E8400 @ 4.02 (445 MHz x 9), CPU voltage 1,34
Zalman CNPS9500A LED Fan (92mm)
Corsair Dominator PC8500 4GHZ (1069 MHz)
Asus P5Q-Pro
Sapphire ATI Radeon 5850
WD caviar black 640GB x 2 in Raid 0
Antec Skeleton Case
Windows 7 Home Premium 64bit
Any ideas how to reach perfectly stable 4GHz on E8400?
Thanks in advance
Asus P5Q-Pro
Antec Skeleton Case
Thanks in advance
