) The temperatures are 65 degrees under load using an Intel stock cooler. The memory is set to 1:1 so runs at its native 800Mhz and the voltage is put up to the first red on the motherboard (where it says it may affect stability, 1.26V or something like that, I'm at work atm, so I can't check). The memory timings are set to 5-5-5-18 and the system is running on 2x2GB Corsair PC6400. The motherboard is an MSI Neo-F P35. I have overclocked an E2200 successfully to 3Ghz (no higher as I want it 100% stable and am selling it + its on stock fan), albiet on a nvidia 650i based ASUS board so I have a rough idea of how to overclock. This computer has me stomped though. Is it safe to raise above 1.26 volts or is the motherboard telling me the truth? I'm not too happy about the temperatures getting too high either (above 70 degrees under load). Any help would be appreciated.
. GUYS GUYS !
Not like i wanna say anything, but some of the worse C0 chips are not meant to get to 4ghz on just 1.26v .
I am pretty sure the crashes are there because of your CPU voltage and not the actual ram.
Put the CPU on 1.35v in bios, mch+0.2, disable EIST and C1E, boot in and watch temps using core temp and real temp.
Then see how it goes.
If your going to overclock the chip, I would reccommend a 3rd party cooler.
You are lucky to get it to 3.4Ghz with a stock one. Not sure about yours but the HSF I got with my E8400 had no copper base whatsoever. Ideal for default speeds but nothing else.
These chips are safe enough to push 1.4v through so you have plenty of headroom. Just get a better cooler on it first.
Also take a look at your case cooling. Do you have enough air passing through?
Will it run fine at stock?
CPU@3Ghz
Memory@800Mhz
If so, take out 2Gb of the memory and leave 2x1Gb sticks in. See if you can get your overclock with that. It may just be that the motherboard cannot take the 4x1Gb sticks overclocked.
Unfortunately, there are some memory modules that just will not budge above their stock speeds.
CPU@3Ghz
Memory@800Mhz
