Got my E8500 up to 4ghz and I'm just in the process of getting it 100% stable. It boots into windows fine however I can't run Orthos for long without an error (doesn't crash the computer though).
Spec in Sig. Running at below speeds, as you can see it runs superpi but errors after 1 min of Orthos. I have slackened the mem timings to 5-5-5-15 and I can now get about 30 mins of Orthos. Memory voltage is also up to 2.2 (stock is 2.1).
At the moment I'm at work and PC is at home running memtest to check the memory is OK at 842mhz. Whats my best plan of attack for getting it more stable? Any suggestions would be much apreciated.
Cheers
Dave
Cheers
Dave
