Easiest and cheapest way to get internet without WiFi
5 Jul 2019
Hi there,
Sometimes my internet goes down and I have to use 4G through my mobile phone network provider. This is fine on my phone, but when I need to use the internet on my PC/laptop, I am stuck.
Can anyone suggest the best way I an get internet using 4G on my PC. Would a dongle be the best option? If so, are they relatively cheap and easy to set up?
Any ideas would be great, thanks
In order of cost of solutions I can think of, probably
Cable tether if your phone supports it as already suggested >> Old router if you have one that be repurposed as a wireless bridge tethered to your phone >> wifi dongle/card for the PC to tether wirelessly to the phone >> buy a wireless bridge to tether to your phone. All options <£20 I should think.
