It sounds like an easy thing to do, but I can get my head around the "best" way to do it.
One side of my hallway has my BT master socket, the other side has power, my router and my desktop.
Currently, I've just got the cable running along the floor covered by a rug...
Options are;
Go down. We are actually getting new carpet soon, so I could probably have a play easy enough. The floor is solid concrete, so I guess I would have to cut a groove into the concrete to prevent having a raised bit of carpet? My DIY skills are not without limits. I've never used and angle grinder, but whatever, I guess I could give it a go lol.
Go up. Drill 2 holes in ceiling. Put wire through floor of 2nd floor. I guess this is more sensible. Seams kinda silly to go through the ceiling for like 1.5m, then drop down. Its also going to make the cable longer than the other route, which is not ideal for a DSL cable.
What do you think?
Options are;
What do you think?
