Hi Ive got a Gigabyte GA945P-S3 Motherboard, it comes with EasyTune 5 which I installed, I updated it, now when I start the computer it says my cpu settings have been changed and it will go to default.
Ive unistalled it, my question is do I need it?, is it any good?, and whats the best way/program to overclock my computer.
. Also is nvtray the best program to overclock my videocard and should I just click on detect optimal settings on manual overclocking(as thats the only option I have).
System Specs:
CASE: AKASA ZEN MIDI ATX IVORY WITH 2 SILENT 12CM FANS AT FRONT AND REAR.
PSU: HIPER 580W PSU
CHIP: INTEL CORE2DUO E6600 2.4GZ
MOTHERBOARD: Gigabyte GA945P-S3 Socket 775 FSB 1066mhz
GRAPHICS CARD: NVIDIA GEOFORCE 7900GS WITH 512MB DDR 3 MEMORY, OVERCLOCKED USING NVTRAY
MEMORY: 2 GIG DDR2 DUAL CHANNELED 533MHZ SPEED, BOTH KINGSTON AND DELL (NOT SURE OF MAKE)
MONITOR: 17" DELL FLAT PANEL
SOUND: DELL 5.1 SPEAKER SYSTEM, 5 SPEAKERS AND SUBWOOFER.
OPERATING SYSTEM: WINDOWS XP MC EDITION 2005
Thank you very much
. Also is nvtray the best program to overclock my videocard and should I just click on detect optimal settings on manual overclocking(as thats the only option I have).System Specs:
PSU: HIPER 580W PSU
Thank you very much
