tolien said:It will stick if you keep synching at 160kbps. It's not the throughput that's the problem per se (since that's the expected behavior of the BRAS limit setup), but the low sync rates.
Did the BT engineer's modem also show the low sync rates?
Yes. I only get low sync rates after hours of it trying to sync at 7000. But even for the few mins on 7000 (before it drops) all I get is dead on 56kb/s.
I'm not sure this OpenReach guy could be called an engineer. He seemed to know very little, and could only offer me a "give it three days". He said it was a "tricky one".
Sat here, with router in front of me, all I ever get is "retrainig, up @ 7616kbps, down, retraining, up @ 7616kbps, down..." for the last 10 days. After about 100 or so cycles of this, it will sync to 160kbs, and stay up. No improvement, no difference at all.
