Edge links pinned to taskbar
DAS
DAS
1 Feb 2007
Enfield
I have two websites pinned by Edge to my taskbar via the browser's menu, but they seen to be identified as apps rather than shortcuts, so cannot be unpinned. The option is being offered to uninstall the "app", but that would mean the entire browser. I have not had this problem previously so I guess it's a change in how Edge handles them. I know there have been problems unpinning Edge itself, but I can do that which makes it even odder.
I have tried numerous things without success, including repairing/resetting Edge. I am loathe to reinstall Edge from scratch as it's not that crucial, but wondered if anyone else has encountered this?
Thanks
David
Apps can be unpinned from the taskbar without needing to uninstall.
When you right-click the icon, is "Unpin from taskbar" not shown?
You should be able to unpin with a simple right click to bring up options?
Also you can't uninstall Edge, not unless you use something like winutil script to remove it completely.
What windows you running?
Unpin from taskbar appears as the only menu option (other than the link itslelf) but does nothing. Windows 11.
I think it a corrupt taskbar/registry entry but whatever I try, it refuses to budge.
Bizarrely, I can now unpin these links. There must have been some update in the background today.
Thanks for your replies.
