Hello,
I will be moving into a new build property next month and will be in need of a shed.
I plan to stay there for quite some time so want to invest in a decent shed.
The shed I will buy will be 10' x 8'
I found (what I considered) the perfect shed at www.acesheds.co.uk
Their site allows you to customise your shed with things like increase sized frame and flooring etc. The price wasn't bad either I configured a strengthened shed with opening windows for about £940ish
The problem I have found is I am well out of their delivery area.
I am in Derbyshire so I started looking around and found a place called easyshed.
Their shed comes in at about £1050 but the windows aren't of the same quality and the frame is a bit smaller (38x50mm vs 65x38mm at acesheds)
I can also not upgrade the cladding at easy shed without a significant hike in price
At ace sheds I was able to add loglap cladding which whilst I haven't got my heart set on this does look a lot nicer to me.
So is their anywhere that delivers to the derbyshire area that can compete with ace sheds ?
Also is is loglap ok as a pose to shiplap ? in my mind the shape of it would increase its strength over normal flat cladding.
Thanks for looking
Thanks for looking
