I have a Thermaltake Soprano case. http://www.thermaltake.com/xaserCase/soprano/bws/bws.htm
I find it OK, except for the fact that it's too small for all the stuff in there so ambient case temp is running too hot. Up to 45deg IIRC. I think it's hindering my CPU overclock as well.
The case has 2 120mm fans, front and back, and one side 90mm fan.
My questions is would there be any benefit in replacing some or all of these fans? I don't mind buying some premium fans if it will lower temps by a few degrees. I presume the rear 120mm fan would be the most important and have the most effect.
Any opinions please and any experieces with temp drops between fans. Thanks
