You shouldn't need too much oil if you are cooking fried rice, I use cold pressed rapeseed oil (it's a pretty good all rounder). Is your cooked rice dry, dry rice should fry well.
How I cook my rice (this is for white long grain rice, cooked so it is dry and not clumpy):
Wash 1 cup of rice (Put rice in sieve and run water from the tap over it - maybe you don't need to do this these days, I do it mostly out of habit as I've been doing it that way for the last 30 odd years!)
Add 2 cups cold of water to pan and bring to boil
Put on lid (must be tight fitting) and simmer for 8 mins
Take off heat and leave with lid on for 8-10 min
Do not remove the lid until the rice is ready or it won't come out right. If you use a heavy pan with a tight fitting lid it comes out best. If not - use a tea towel between the pan and the lid (make sure the tea towel is folded up so it doesn't get burned).
