EGR Valve Cleaning
24 Nov 2007
Leeds
Hello all,
Tomorrow i'm going to clean the EGR valve on my friends 1.0 Corsa! fun times!
I'm just wondering what would be the best thing to clean it with?
Carb Cleaner? WD40? some have suggested Petrol?
Any advice would be great.
Thanks.
Gil.
So you have done the same task your self?
If so, i read that the gasket is easily broken while removing the EGR valve, is this true?
Not on a corsa no so I cant comment on the gaskets..
I did it on my Mondeo and didnt have a problem with gaskets although its a messy job. Wear gloves because the crud will NOT come off your hands (although mine was diesel so its different crud, I wouldnt risk it...)
Thanks, i'll be getting the marigold gloves out then!
Any pointers on a good carb cleaner to buy? Never bought any of the stuff before tbh. Do i just pop down to Halfords and grab what ever is there?
You might get away with running a can of 10k Boost through the engine.
No need to remove the EGR valve.. just spray the can down the air intake.
When I did mine halfords only had one type of carb cleaner - Winns I think..
Thge winns carb cleaner and the 10k boost work in the same way do they not?
It's just winns is half the price of the 10k so don't want to shell out if i dont need to.
Myself and NickXX used this to clean his EGR valve on his chipped 330d on Sunday.
We had tried to clean it a few weeks earlier with a toothbruth and water, but it was on solid. Sprayed ont he carb cleaner and it just poured out the other side.
Total time to do it was about 45 minutes including removing and then refitting.
carb cleaner small screw driver and a little wire brush/toothbrush is what you want, just spray it in the carb cleaner will break it up and a lot of it will just fall out if you give it a gentle tap against something solid, the rest you can get out by scraping and spraying it, you will probably have a mesh filter too soak this in petrol then clean with a tooth brush.
I was under the impression that 10k Boost can be sprayed into the air intake with the engine running.
Whereas carb cleaner could only be used with the engine off? and carb in hand as to speak.
Feel free to correct me ;)
This is what i was wondering also.
I can only echo the wear gloves, I did my mondeo tdci and didn't - had dirty black hands for about a week!
Other than that it's an easy job and made a big difference.
Yeah - you're best off removing the EGR valve and doing it properly rather than cleaning it in situ.
Don't try cleaning it in the kitchen sink. I did mine on the lawn.
Recently did one on a 1.4 16v Corsa, was a metal gasket so not issues of it breaking, but it was a total git to get to.
Cleaned it with WD40
I think its special Ford brand TDCI dirt, the only way to get it off is to remove skin!
