No.
Backplates are affixed to the block, block are not universal, so backplate are never universal.
gtx780 bitspower block with ek 780 ref model backplate.Its only i saw a video and it showed this combo thats all.gtx780 bitspower block with ek 780 ref model backplate.
can anybody tell me if the EK back plates are universal, ie im getting a bitspower waterblock for my GPU as its the only full block i can find for the gtx 780, but want to fit a EK back plate, will this work.
Which 780 do you have?
, really need to know this as ive a custom designed parvum case coming in a few weeks, have tried to find a EK se full model but due to E.O.L cant get one anywhere.
Oh, then that is a different story.
Backplates might be compatible across the brand.
But you might have to purchase additional screws to screw the backplate into the block, but the screw holes should line up if both the blocks and the EK are compatible for the card.
thanks for getting in touch Luc , ive a evga gtx780 sc ref model., really need to know this as ive a custom designed parvum case coming in a few weeks, have tried to find a EK se full model but due to E.O.L cant get one anywhere.
You're looking at the SE model because you want a plexi block that will cover the whole card.
Sadly since it's EOL, the only way to find one is from used sales.![]()
yes i know, but as i cant find one at the moment will the EK backplate for the gtx 780 ref model fit on the back of the card if i use a bitspower gtx780 water block.
That's a good question! Unfortunately I don't know for sure. But since you've seen it on the other build I would assume that it's possible.
I found a quite a few EK blocks, new and 2nd hand via google. Even OcUK gets the occasional B-grade block for cheap.
Or are you looking for a very specific variant?
dont want seconds really cause of staining and would have to take block apart to clean, void warranty.i want the titan se full block in clear for the gtx 780.dont want seconds really cause of staining and would have to take block apart to clean, void warranty.
Would EK refuse a warranty claim due to a customer opening up their block?
Not at all![]()
