Ek Liquid Nitrogen cooling
Liquid nitrogen is, unsurprisingly, expensive.
It has a socket-specific mounting system enclosure that allows even newbies to the overclocking profession to try their hand at it.
Many dead motherboards. Not EK's problem though.
Meanwhile, the main body is made of electrolytic grade nickel plated copper, with “excellent weight to surface area ratio.”
Copper is expensive, so they made it thin. This means it won't have much heat capacity. That's probably a bad thing and strange to boast about.
