Deleted member 66701
Where's the 970 blocks?
None planned but some 670 blocks fit (if you can find any in stock).
I'm putting a couple of EK Thermospheres on my Galax 970 EXOC's.
Any news on 970 blocks at all?![]()
Anyone know if the EK Water Blocks EK-FC980 GTX - Acetal http://www.overclockers.co.uk/showproduct.php?prodid=WC-652-EK&groupid=962&catid=1520&subcat=2885 are compatible with the backplates that already fitted to the EVGA 980 reference design cards?
If you read the product description it says it does.
"Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M2.5 DIN7985 screws and allows for re-use of the original NVIDIA backplate."
