EL wire / string
3 Mar 2006
Atcham, Shropshire
has anyone got some of this el wire? can you tell me how bright it is?
i'm looking to do a mod but need some low heat bright lighting, i'm currently using LED's but the light is too direct and i need a more spread out type of light and i thought EL wire might just do the job.
so if you have any then how bright does it glow ;)
I had some a few years ago and it almost set fire to me room :eek: :eek:
Could've changed though :D
If i can remember rightly it doesnt shine out like a led, but in the dark you might get a dull blue and just about see other components.
This was a few years ago though :D
yeah i had heard a few horror stories but that was mainly about the glowing sata cables setting on fire etc.
where i will be putting them is rather inaccesible so safety is paramount, hmm anyone else got some and not had it set on fire :D
