Electric Air Dusters?
4 May 2009
Edinburgh, UK
Coming up on a year since I built my current rig, and it could do with a decent clean. Coupled with this, I've just bought some Lian Li fans, so I'm going to be partially disassembling it anyway.
I'm looking at blower options for cleaning. Something in me objects to paying £4 for a can of air that's just going to have to get recycled, and so I was wondering about getting an electric duster.
Do any of you have experience with these? Am I being stupid in objecting to the canned air?
Toying with this idea myself. The IT boys at work got one a while back and sang its praises over the canned air.
I bought one of the compucleaner it dusters a year or so ago, use it fairly regularly not only to clean out the PC, but other things like coffee grinders etc :) it's loud but does a really good job.
I picked up a Compucleaner for a friend a couple of years ago. Was fun seeing it blast surprising amounts of dust out of GPUs and radiators.
I'd recommend them and don't think you're being silly about the canned air.
This will be getting one for my birthday.
I bought a usb charged car blower/vacuum from the forest based online store, works a treat for my uses and is cheap as chips. Much better value (long term) than cans of air. Great for cleaning keyboards, rads and gpus (from my use anyway)
I use a £15 airbed blower thing I got for our blow up mattress. It's noisy as hell but it'll blow you nads off, and the dust attached.
I was wondering about what caused the 4x cost increase between the airbed inflators and the computer-specific equivalent. Thanks for confirming "little to none".
Can you post the make and model? Interested to see.
You might end up a bit disappointed with the amount of air pressure, though it'll probably work to a degree. I can speak to the IT Dusters though, they work great, myself and my father have one and they do a fantastic job. They'll never compare to a proper air compressor, but then they are an order of magnitude cheaper. No idea why the price has jacked up as much as it has in recent years(capitalising on increase sales i guess), picked mine up just over £30 years ago and dad grabbed his early last year at £38 (on some obscure website i advised against using, worked out fine though). A cheaper alternative potentially with a decent amount of air pressure as someone else mentioned might be airbed pumps (but i've never used one, so can't speak to how well they work comparatively).
Got a link or a name of a good one?
I have an Airmaster Tiger. Equivalent model today: https://www.machinemart.co.uk/p/airmaster-tiger-7250-2hp-24-litre-oil-free-ai/
Think I got it on on sale for a bit cheaper.
Same sized Einhell ones get a good review on amazon and can be had 80-95 depending where you look.
There's an Impax on Screwfix for £110 which looks pretty darn similar to the Airmaster. But they also do a Stanley one with a little less power for £100.
I'd buy any of those. Just keep an eye out for any deals. Might get something in black friday.
I've had really cheap ones from B&Q before which broke after a couple of years. Valves in the head snapped.
second this.
Got tired of constantly buying new air cans or putting off cleaning the pc because I wasn't bothered to order new ones, So I bought a compucleaner and keep it next to my desk. Much better investment imo.
I have to admit, when you said 'mini' compressor, I was assuming something a lot smaller than that!
But looking myself, I'm only finding ones that are purely for tyres, or ones for airbrushing. (Or ones that are massive like yours!)
Haha. They're very mini compared to most compressors. Most are hot water tank sized.
