It sounds like miniyazz is using his bike exactly like I do which is to put loads of effort in and then just use the electric when you need to. I said above that I sweat more on my eBikes than I do on my other bikes because I can.
Sure but you're missing the benefits though if you aren't using the motor all the time, you can put the same amount of effort in but go a lot faster. £1,000 is a lot of money to spend on a bike that you rarely use the features on. I get over 20 miles out of my bike with maximum pedal assist on all the time and no speed restrictions, that's the motor on 90% of the time at full power, so if you are only getting 15 when you aren't using the motor much it sounds like something is wrong.
It depends what cells were used in the batteries though, the source doesn't make the cells in the batteries. If there is no pedal assist being used then there's no way it could be using more power.However the three batteries have been bought from the same source!
It would be great to bypass the computer/pedal assist to see how much more I can get out of it.
