When you drive a normal car it is charged the battery right?
Why can't worries cars charge themselves as they drive?
Driving south presumably?As above. I've even seen mine go up a % when going down a very long hill!
Technically you could if your credit line was infiniteFollow up - why can't I pay a credit card off with a credit card, rinse and repeat forever? Free money?
Is it just a case of lacking effective energy capture
Wipers, indicators, etcWhy do electric cars need a standard 12volt car battery?
pfft I want 400Volts minimum going through my wipers.Wipers, indicators, etc
Yes, not a problem.pfft I want 400Volts minimum going through my wipers.
cant they transform down to 12V off the big battery?
The issue is mainly parasitic drain from ancillary systems when the car is off. That and the fact that when the car is off, the HV battery is physically disconnected from the driveline with contactors. You’d rather ruin a “cheap” 12v battery by draining it too low than ruin your £15,000 HV pack.pfft I want 400Volts minimum going through my wipers.
