Trigger said:Yeah, but it will most likley be two core cable- i.e. have no earth which it requires![]()
Shush, you're making me look stupid. And i don't need any help for that
fluiduk said:Now you have lost me.
Surely if the light that the switch and cable is currently on doesnt have an earht, and it doesnt, then why does the new one need one? The back of the fitting isnt open.
The reason I want to use the fitting on the plug is because I am using it as an uplighter not a ceiling light. The light is going to be fixed to a piece of MDF.
What would you recommend?? Other than any major electrical socket moving, as I cant do that
Cheers
Aaron
Trigger said:It must then have an inline switch rated at 13 amps and then have an RCD breaker wired directly on to the end all wired in 1.5mm squared 3 core flex![]()
Adam_151 said:Why? As long as the design current is lower than the overload protection (the fuse) and that is lower than the current the cable is capable of carrying continously then its ok. The design current of this is going to be less than an amp as the fixure will only be used with 50w or smaller lamps (never seen a GU10 > 50w and even if they did exist, I bet the fitting has a max wattage of 50w per lamp due to heat issues) to install 1.5mm² flex and a 13A BS1362 is completely pointless, 0.75mm² flex on a 3A BS1362 will be fine, though you are right about the earth, and I'd be interested to know why you suggest putting an RCD on it, as long as its constructed properly an RCD is not needed and anyway an RCD is not an excuse for sloppy work
Sorry if my reply is a bit muddled, i'm trying to cook tea at the same time
I can't see why its necessaryTrigger said:Err.. who said anything about sloppy work? All portable light racks like spots and stuff all have RCD's on them to protect them.
Sorry I mis-read you post slightly, but the core point is still there, to use 1.5mm² flex would be over engineering itSecondly, who said anything about 13A fuses?
Yes, and 0.75mm² flex is perfectly ok for a 3A fuseThe supply cable should be bigger than the protecting fuse
Depends on the nature of the fault current, fuses are better at clearing large fault currents because their let through energy is more a less constant, whereas with MCBs the let through rises in proportion with the square of the fault current, for fault currents in the hundreds rather than thousands of amps, yes an MCB will be fasterand fuses don't 'burn-out' on overload as well as MCB's and RCD's so
Why do you need such protection though, RCD protection is generally employed where the Zs are too high for the overcurrent device to protect against indirect contact (such as in a TT system) or where there is a risk of direct contact (such as from cut mower cables)and although the RCD doesn't directly stop overload, it will protect it in the sense of an imbalance of current between the live and neutral
No, you got it right above- i.e. if something is drawing more current than it shouldIndeed, but where is
fluiduk said:The unit does not have a connection for an earth lead? Where does that leave me lol
fluiduk said:Sorry that was my bad, just taken the cover off and found it.
It has an earth connector
fluiduk said:Cool, thanks. I will goto the well known, but rubbish electricals store tommorrow and see what they have. thanks for the help.
Ps is it ok to wire it up with the lead i have now just to check it works before I goto the hassle of spending all my money lol? Or will i blow up?
Thanks
Trigger said:Well you want a 3 core cable, anything above 0.75mm will do (Although I would stil say at least 1.0mm) with a 13A inline switch and a 3A fuse. I would still put an RCD on the end though just for added protection and they don't exactly cost the earth now do they as they used to cost £100 upwards![]()
Trigger said:What's your problem? It costs a few pounds and gives added protection to a portable device, why not![]()
fluiduk said:Ladies! lol
For the record I will be putting an RCD on it, as I have one spare lol.
What does 40/0.2mm mean with regard to the thickness of the cable?
Aaron
wandgrudd said:What’s my problem? Well I can’t see any reason why he needs to add an RCD to a light. Why spend money on some thing that’s not needed. (cant see where it says its going to be portable)
Would probably be better looking at Screwfix IMO
