- 16 Mar 2009
Hi all looking for some help on this...
RTX 3080 gpu and a Creative Soundbalster AE-5 soundcard.
Using my speakers through 3.5mm speaker input I get electric interference through the speakers (deffo not coil whine) whenever the GPU is under load. When not gaming etc it is fine.
If I use toslink / optical for sound then this does not happen.
I have tried with a 3080 FE and an MSI gaming X trio 3080 and both cause this issue. I was running a Zotac 1080TI before and this did not have the issue. I have also tried a ground loop noise isolator but this does not work either.
Its related to 3.5mm speaker inputl and is only since using a 3080, 100% not coil whine.
Any advice?
Any advice?
